Il faut modifier le fichier tts.inc qui se trouve de /usr/www/cgi-bin/ par le code ci-dessous: (faire une copie de l'ancien au cas oĂą)
- Code: Tout sélectionner
function AcapelaTTS {
TTS=$1
VOICE=$2
NOCACHE=$3
RVOICE=$4
MUTE=$5
MD5FILE=""
CURL_PARAM=$(echo "?MyLanguages=sonid15&MySelectedVoice="$RVOICE"&MyTextForTTS="$TTS"&SendToVaaS=&t=1")
RESULT=`eval $(echo "curl --request POST --header "Keep-Alive:300" --header "Connection:keep-alive" --header "Content-type:application/x-www-form-urlencoded" -s --data '${CURL_PARAM}' http://www.acapela-group.com/demo-tts/DemoHTML5Form_V2.php")`
position_depart=$(awk -v a="$RESULT" -v b="var myPhpVar = '" 'BEGIN{print index(a,b)}')
LIEN=${RESULT:${position_depart}+15}
position_fin=$(awk -v a="$LIEN" -v b="'" 'BEGIN{print index(a,b)}')
RESULT=${LIEN:0:${position_fin}-1}
if [ "$RESULT" != "" ]; then
MD5FILE=$(echo "$TTS$VOICE" | md5sum | cut -d ' ' -f 1)
echo $( echo \"$TTS\" | UrlDecode) > $CNF_DATADIR/Tmp/${MD5FILE}.txt
echo $( echo $RVOICE | UrlDecode) > $CNF_DATADIR/Tmp/${MD5FILE}.voice
eval $(echo "curl -L -A '${UA}' -o $CNF_DATADIR/Tmp/${MD5FILE}.mp3 $RESULT" ) >>/dev/null 2>>/dev/null
if [ "$5" != "1" ]; then
Log "[TTS]" "Playing sound ${MD5FILE}.mp3"
PlaySound $CNF_DATADIR/Tmp/${MD5FILE}.mp3
fi
if [ "$NOCACHE" == "1" ]; then
rm -f $CNF_DATADIR/Tmp/${MD5FILE}.mp3 >>/dev/null 2>>/dev/null
rm -f $CNF_DATADIR/Tmp/${MD5FILE}.txt >>/dev/null 2>>/dev/null
else
Log "[TTS]" "Storing sound ${MD5FILE}.mp3 to cache"
fi
fi
echo ${MD5FILE}
function GoogleTTS {
TTS=$1
MD5FILE=$(echo "$TTS" | md5sum | cut -d ' ' -f 1)
eval $(echo "curl -A '${UA}' -o $CNF_DATADIR/Tmp/${MD5FILE}.mp3 'http://translate.google.com/translate_tts?tl=fr&q=${TTS}'" ) >>/dev/null 2>>/dev/null
echo $( echo "$RAW_TTS" | UrlDecode) > $CNF_DATADIR/Tmp/${MD5FILE}.txt
function ProsodyTTS {
TTS=$1
VOICE=$2
# Not Working
# Need test
return
# curl -s -d "$TTS" http://188.165.228.65/tts/Suzanne -o $CNF_DATADIR/Tmp/test.mp3
$(echo "curl -A '${UA}' -o $CNF_DATADIR/Tmp/${MD5FILE}.mp3 -s -data '${TTS}' http://188.165.228.65/tts/${VOICE}" ) >>/dev/null 2>>/dev/null
Ne pas oublier ensuite en telnet de faire un
chmod 777 /usr/www/cgi-bin/tts.inc
puis un
dos2unix /usr/www/cgi-bin/tts.inc
