[Plugin] Gestion d'un module RGBW
Re: [Plugin] Gestion d'un module RGBW
Messagede joe144 » 19 Juin 2015, 14:36
Bonjour vosmont,
Je viens d'installer la librairie json mais cela ne marche toujours pas.
Voici ce que j'ai :
09 06/19/15 15:35:18.373 JobHandler_LuaUPnP::Run device 178 RGB controller device room 0 type urn:schemas-upnp-org:device:RGBController:1 id parent 0/0x9a2688 upnp: 0 <0x2ad2d000>
50 06/19/15 15:35:22.416 luup_log:178: (RGBController::startup) Start plugin 'RGBController' (v1.2) __LEAK__ this:40960 start:368640 to 0x10d1000 <0x2b661680>
50 06/19/15 15:35:22.416 luup_log:178: (RGBController::initPluginInstance) Init <0x2b661680>
50 06/19/15 15:35:22.417 luup_log:178: (RGBController::HYPERION.init) DEBUG: Init <0x2b661680>
50 06/19/15 15:35:22.417 luup_log:178: (RGBController::initPluginInstance) Device #178 of type HYPERION is OK <0x2b661680>
06 06/19/15 15:35:22.418 Device_Variable::m_szValue_set device: 178 service: urn:upnp-org:serviceId:RGBController1 variable: Message was: now: #hooks: 0 upnp: 0 v:0xaf78f8/NONE duplicate:1 <0x2b661680>
50 06/19/15 15:35:36.125 luup_log:178: (RGBController::setTarget) DEBUG: Set device status : 0 <0x2ad2d000>
50 06/19/15 15:35:36.126 luup_log:178: (RGBController::HYPERION.setStatus) DEBUG: Switches off <0x2ad2d000>
01 06/19/15 15:35:36.128 luup_require can't find dkjson <0x2ad2d000>
50 06/19/15 15:35:36.141 luup_log:178: (RGBController::HYPERION.sendCommand) DEBUG: Connect to 192.168.0.2:19444 <0x2ad2d000>
01 06/19/15 15:35:36.145 LuaInterface::CallFunction_Job device 178 function SSwitchPower1_SwitchPower1_SetTarget_job failed [string "-- Plugin constants..."]:450: attempt to call field 'encode' (a nil value) <0x2ad2d000>
01 06/19/15 15:35:36.146 Lua_Job::Run job#11 : dev:178 (0xeb0830) P:50 S:0 failed <0x2ad2d000>
joe144
Messagede joe144 » 19 Juin 2015, 20:26
Mon problème est maintenant réglé.
Merci Ă  vosmont pour son aide.
Il fallait en fait installer la librairie json suivante : http://code.mios.com/trac/mios_genericu ... 0/json.lua
En effet le lien posté dans cet article (http://www.domotique-info.fr/2013/05/co ... vera-tuto/) ne fonctionne pas.
joe144
Messagede vosmont » 19 Juin 2015, 21:00
J'ai mis Ă  jour la doc d'installation :
http://forum.micasaverde.com/index.php/ ... 613.0.html
ContrĂ´leurs: VeraLite UI5 / VeraEdge UI7 + Rfxcom Rfxtrx433 + enOcean / openLuup + edisio
Interface: ALTUI / ImperiHome / Sarah / Karotz
DĂ©tecteur ouverture : Vision Security ZD2102
DĂ©tecteur mouvement : Fibaro FGMS-001- Blyss - Chacon
Mesures : Oregon THGN132N / THGR122NX - Owl CM180
Prises / Eclairage : Everspring AN157-6 / AN158-6 / AD142-6 - Fibaro FGS-221 / FGD-211 / FGRGB-101
Sécurité : Foscam FI8918W - Onduleur - Fortrezz FOR_SSA1(sirène)
Divers: Proliant N54L + Xpenology + EmonCms
vosmont
Messagede vosmont » 07 Juil 2015, 15:05
La version 1.31 est disponible sur apps.mios
Nouveautés :
- compatible AEOTEC RGBW Bulb
- ajout de la gestion de dimmers
- compatibilité avec ALTUI
- gestion de transition entre deux couleurs (pour tous les modules gérés)
vosmont
Messagede vosmont » 09 Juil 2015, 12:11
La version 1.32 est disponible.
Principales nouveautés :
- gestion de l'Ă©tat du module
- correction sur des injections multiples de CSS
- correction du colorpicker sous Firefox
- correction de CSS
vosmont
Messagede Pitt13 » 02 AoĂ» 2016, 11:24
j'ai installé la version v1.7.830 sur ma vera3 et le plugin RGBW ne trouve plus le module Fibaro, seul le RGB dimmer me permet de gérer mon ruban LED.
Du coup je ne peux plus déclencher les programmes intégrés au module.
Comment faire svp ?
Merci d'avance pour vos reponses
Vera3 + VeraPlus
Testé Raspberry + Razberry + OpenRemote + MyVera + Jeedom
Messagede kaya » 02 AoĂ» 2016, 17:49
J'ai rencontré le même problème lorsque le suis passé de UI5 à UI7 avec le dernier firmware et après avoir cherché de longues heures.... j'ai trouvé sur le forum micasaverde une solution qui marche et qui consiste à modifier le fichier J_RGBController1.js
Re: PLUGIN: RGB Controller (UI5 & UI7) - V1.33
« Reply #202 on: July 22, 2016, 03:15:55 am »
• Quote
@jvanhambelgium - Thanks, that works perfectly. Appreciate you taking the time to help those of us less code savvy.
@vosmont - any chance of updating the plugin for future generations?
For the future generations in the mean time, I've attached the file that needs to be replaced on Vera. Download it and rename it to J_RGBController1.js before uploading.
J'ai bien le fichier modifié mais je ne sais pas comment ajouter des pièces jointes sinon retrouve le post sur le forum mica
Après avoir du refaire quasiment toutes mes scènes sous UI7, j'ai encore des erreurs "device can't detect", une portée inférieure à UI5 pour les modules les plus éloignés, et des bugs matinaux avec "luup is night".... si c'était à refaire, je retserais sous UI5 qui fonctionnait très bien
Kaya
vera 3 UI7, serveur proliant whs 2011, HS3
30 modules z wave, thermostat et station netatmo, ethernet controller TCM181B
Imperihome, myvera, itow sur rasberry, 3 squeezebox radio, Karotz
2 tablettes 7 et 1 tablette 10
kaya
Messagede Pitt13 » 03 AoĂ» 2016, 11:44
Merci pour ton aide, j'ai retrouvé le sujet sur le forum micasaverde, j'ai fait la modif mais ilbne trouve pas module Rgbw Fibaro, par contre il affiche la ligne des animations
Vera3 + VeraPlus
Messagede vosmont » 05 AoĂ» 2016, 10:14
je suis en vacances avec une connexion limitée.
Je regarde ça la semaine prochaine :)
vosmont
Messagede Pitt13 » 05 AoĂ» 2016, 10:55
Le support vera à forcé la prise en compte du module Fibaro. Apparemment avec la maj v1.7.830 il y a quelques soucis, à l'installation de la maj ça supprime le module existant et réinstalle un nouveau module... Sympa pour la prog déjà faite... Et un cercle de couleur est ajouté, comme ton plugin en fait mais sans les animations.
Après l'intervention du support hier, ça fonctionne bien.
Vera3 + VeraPlus
Messagede hornet49 » 04 AoĂ» 2017, 15:15
je viens de passer ma vera UI5 sur UI7, pas trop de problème a part ce fameux modul RGBW de fibaro. Comme vous je n'ai plus la gestion des annimations ce qu'est plutot dommage.
est ce que quelqu'un a trouver une solution ?
Vera en version 1.7.963
Merci d'avance pour vos retours.
caméra APEXIS + barrière IR
serveur WES (V0.7G3) avec:
1 TV samsung (UE46D6300)
1 Freebox mini
2 BoxTV android (MXQ PRO)
1 Autoradio Android (RK3188)
1 Karotz (a vendre lol)
hornet49
Messagede hornet49 » 04 AoĂ» 2017, 15:48
ok j'ai trouvé pour ceux qui cherche réponse ici => https://thedigitallifestyle.com/w/index ... utomation/
1 Freebox mini
hornet49
Utilisateurs parcourant ce forum: willyf et 7 invités
