UI Alternative a UI7
Re: UI Alternative a UI7
Messagede bucolo » 12 Juin 2018, 09:47
j'ai pas vu en fait il y a une erreur apres :
50 06/12/18 10:45:45.193 luup_log:608: ALTUI: debug: Data Provider watch provider:emoncms v:[ { "Data": "[ \"3\", \"2\", \"prise_serveur\", \"dff2bxxxxxxxxxx94f\", \"http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}\" ]" } ] <0x77260520>
50 06/12/18 10:45:45.193 luup_log:608: ALTUI: debug: sendValueToStorage: No url, will use callback instead <0x77260520>
50 06/12/18 10:45:45.195 luup_log:608: ALTUI: debug: sendValueToStorage_emoncms(0-69,urn:micasaverde-com:serviceId:EnergyMetering1,Watts,22.9,23.0,1528793145,[ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}" } ]) <0x77260520>
50 06/12/18 10:45:45.195 luup_log:608: ALTUI: debug: watch_description:{ "Data": "[ \"3\", \"2\", \"prise_serveur\", \"dffxxxxxxxxxxxc21494f\", \"http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}\" ]" } <0x77260520>
01 06/12/18 10:45:45.196 GetLuaInterface can't find device type: 4/0x121bdb8 str: 0-69 <0x77260520>
01 06/12/18 10:45:45.196 luup_variable_get interface 0x172afa8 args 3 <0x77260520>
01 06/12/18 10:45:45.197 LuaInterface::CallFunction_Variable func: variableWatchCallback Device_Variable 69 urn:micasaverde-com:serviceId:EnergyMetering1:Watts failed [string "-- // This program is free software: you ca..."]:3223: bad argument #2 to 'format' (string expected, got nil) <0x77260520>
2
bucolo
Messagede chrifabre » 12 Juin 2018, 13:37
j'ai porté la valeur ControlTimeout a 99999
impeccable cela fonctionne correctement sur mon smartphone, mais aussi sur mon ordi en Remote
j'utilise la derniere versionAltUi v2.27.2414.
J'avais déjà mis la valeur de ControlTimeout à 10000,lors du dernier essai non fonctionnel.
je m'apercois ensuite que j'ai une répétition d'erreur
Duwi  064312 (3) , 064459 (1)
Aeon DSC12104
Remotec ZXT-120, ZRC-90EU
Swiid SwiidInter(3)
BENEXT TagReader
Karotz
Google Home / Alexa
HP Proliant + XPEnology
Lecteur RFID modifié Zwave
chrifabre
Messagede amg0 » 13 Juin 2018, 17:42
@chrifabre
il se passe vraiment des choses etranges, mais je pense qu'on est a la limite du raisonnable dans ta configuration. 3 vera et en remote access ca fait trop. il faut repenser le setup pour optimiser les temps reseau. soit faire avec un VPN, soit ne pas faire du multi-controlleur,
amg0
Messagede amg0 » 13 Juin 2018, 17:53
bucolo a Ă©crit:j'ai pas vu en fait il y a une erreur apres :
2
interessant, ca explique les symptomes. ca veut dire que la variable emoncmsurl est nulle ou pas trouvee !
local emoncmsurl = luup.variable_get(ALTUI_SERVICE, "EmonCmsUrl", lul_device)
debug(string.format("emoncmsurl:%s",emoncmsurl))
est ce que tu vois cette variable dans ton device ALTUI ?
quel est la chaine du service pour cette variable ?
quel est ton numero de peripherique ALTUI ? est ce 608 ?
que retourne luup.variable_get("urn:upnp-org:serviceId:altui1", "EmonCmsUrl", 608) ?
essaye de faire un MISC/DEBUG : Fix Devices's state avec le parametre "0-608"
si ca ne marche pas , essaye de remplacer ce code ( ligne 3223 )
par celui ci
   lul_device = tonumber(lul_device)
amg0
Messagede bucolo » 13 Juin 2018, 21:50
Oui je vois bien la variable emoncmsurls dans le device Altui
J'ai pas tout compris la suite de ton message mais j'ai compris la fin et ça marche :)
en ajoutant : lul_device = tonumber(lul_device) ca marche
Merci !
Sinon, pour changer de sujet, j'ai recu une amazon echo ce matin et m'amuse comme un petit fou avec :)
La skill vera n'est pas dispo en france mais ont peut l'installer quand même. J'avais installé ha-bridge sur mon serveur en pensant que la skill vera marcherait pas mais j'en ai meme pas eu besoin.
bucolo
Messagede bucolo » 14 Juin 2018, 14:42
alors ca marche mais en local seulement quand j'indique "192.168.1.10/emconcms"
le probleme est qu'il faudrait que j'indique emoncms.mondomaine.com pour que je puisse voir les graphs sur altui depuis partout.
mais comme je fais une redirection en https systematique la vera m'indique une erreur "301 moved permanently"
Il est possible de laisser l'ip local et de changer a chaque fois l'url graphique mais c'est fastidieux.
l'ideal, si ça te derange pas, serais simplement de pouvoir indiquer l'url complete dans EmonCmsUrl avec "https://emoncms.org" comme valeur par défaut (ils sont passé en https eux aussi)
edit:
j'ai fais les modif dans ton fichier (ci-joint) et ça marche bien
Fichiers joints
L_ALTUI.zip
(39.77 Kio) Téléchargé 37 fois
bucolo
Messagede chrifabre » 14 Juin 2018, 17:47
@buccolo
je viens aussi de recevoir Amazon Echo
Comment as tu installé le skill vera ?
Aeon DSC12104
Swiid SwiidInter(3)
BENEXT TagReader
Karotz
Google Home / Alexa
chrifabre
Messagede amg0 » 14 Juin 2018, 19:08
bucolo a Ă©crit:alors ca marche mais en local seulement quand j'indique "192.168.1.10/emconcms"
edit:
bucolo a Ă©crit:Oui je vois bien la variable emoncmsurls dans le device Altui
Merci !
Et ça marche en français ?
amg0
Messagede amg0 » 14 Juin 2018, 21:29
edit:
C'est integre dans la version sur github. merci !
amg0
Messagede chrifabre » 16 Juin 2018, 09:56
@bucolo
Je te relance au sujet Amazon Alexa
Comment as tu fait pour installer le skill de la Vera ...
Aeon DSC12104
Swiid SwiidInter(3)
BENEXT TagReader
Karotz
Google Home / Alexa
chrifabre
Messagede bucolo » 04 Juil 2018, 11:18
n'ayant pas reçu de notification je n’étais pas retourné sur le forum.
Du coups j'ai repondu sur l'autre sujet.
Merci Amg pour la mise a jour , mais du coup c'est mon emoncms local qui bug, une sombre histoire de 'RedisException' , il faut que je creuse.
edit: tout est ok, ca remarche , j'ai desactivé redis dans settings.php de emoncms
bucolo
Messagede fonctionair » 10 Juil 2018, 07:29
J'ai déstocké ma vera2 d'une armoire. Sous ui5, j'avais une version 2015 d'altui. Pour bénéficier de la dernière version, j'ai désinstallé le plugin pour réinstaller la dernière version. Après le redémarrage, j'ai une erreur lua.
J'ai brièvement fait une recherche sur les 47 pages du postes mais je n'ai pas vu de chose s'y rapportant.
Une idée svp,
fonctionair
contrĂ´leur domotique : Vera3, Vera2
Rfxcom USB
fonctionair
