Philosophie de ces scripts ...
Messagede domotics » 21 Nov 2006, 19:03
Mais pourquoi Domotic's écrit-il des scripts aussi compliqués ! Il ya bien une raison, il yen a même plusieurs :
1- Depuis 1999, je fais des scripts, et je trouve qu'au bout de 6 mois, quand on revient sur le script, on a du mal à se rappeler toutes les subtilités ! les contournements, etc Donc mes scripts ont tous la même structure. C'est plus facile à maintenir. Par Exemple:
Sub main
Dim astrDevices
WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "Launching " & G_FOLDER_NAME & " script", G_LOG_FILE
If CheckDevices(G_FOLDER_NAME, G_FILE_INI, G_STATUS_EXIST) Then
   astrDevices       = hs.GetINISetting("COMMON","DEVICES","", G_FILE_INI)
   astrConfig        = hs.GetINISetting("COMMON","CONFIG","..\scripts\config\", G_FILE_INI)
   atabDv             = Split(astrDevices, G_SEP)
   astrNbDv          = UBound(atabDv)
   i=0
   While (i <= Cint(astrNbDv))
      astrDevice          = hs.GetINISetting("DEVICE", "HC", "", astrConfig & atabDv(i)) & _
                           hs.GetINISetting("DEVICE", "DC", "", astrConfig & atabDv(i))
      astrEveryBodySleeps   = hs.GetINISetting("DEVICE","PARAM1","",astrConfig & atabDv(i))
      astrAlarmStatus       = hs.GetINISetting("DEVICE","PARAM2","",astrConfig & atabDv(i))
      astrBLOCKINGTV       = hs.GetINISetting("DEVICE","PARAM3","",astrConfig & atabDv(i))
      astrStatus = ""
      If (astrAlarmStatus <> "") and (hs.DeviceStatus(astrAlarmStatus) = G_STATUS_ON) Then   ' Alarme On
            astrStatus = G_STATUS_OFF
            WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "TV : " & astrDevice & " is switching off because the alarm is on", G_LOG_FILE
         ElseIf (astrEveryBodySleeps <> "") and (hs.DeviceStatus(astrEveryBodySleeps) = G_STATUS_ON) Then    ' Tout le monde dort
            WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "TV : " & astrDevice & " is switching off because everybody is sleeping", G_LOG_FILE
         ElseIf isPeriod(astrBLOCKINGTV, "") Then
            WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "TV : " & astrDevice & " is blocked", G_LOG_FILE
         Else
            astrStatus = G_STATUS_ON
      End if
         If (astrStatus <> "") Then
         SetDevice astrDevice, "", astrStatus, ""
            WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "Sending " & astrStatus & " to TV " & astrDevice, G_LOG_FILE
         End if
      i=i+1
   Wend
Else
   WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_SEV, "Expected Device is unknown !", G_LOG_FILE
End if
WriteLog G_FOLDER_NAME, G_SCRIPT_EVT, G_TIV_INF, "End of the script", G_LOG_FILE
End sub
2- Avant, je créais mes events et mes devices via l'IHM de Homeseer. Mais chaque fois qu'on fait une réinstallation, on se rappelle plus les devices, les codes et les events. Ce qui nous oblige à gérer des sauvegardes, de faire des docs, ... et dans la réalité, on a jamais le temps de faire tout ca ! Donc mon principe est de paramétrer mes scripts via des properties, et tout se créé tout seul. j'ai juste à mettre une ligne dans le fichier startup.txt. Par exemple, chez moi, j'ai :
Sub main
'-- MODULES TO BE INSTALLED or UNINSTALL
   hs.run "modules\MY.MACROS\scripts\install.vbs"
   hs.run "modules\RUN.ALARM\scripts\install.vbs"
   hs.run "modules\GET.METEO.FROM.YAHOO\scripts\install.vbs"
   hs.run "modules\GET.TEMPO\scripts\install.vbs"
   hs.run "modules\GET.NEWS\scripts\install.vbs"
   hs.run "modules\REBOOT\scripts\install.vbs"
   hs.run "modules\CHECK.MEMORY\scripts\install.vbs"
   hs.run "modules\READ.1-WIRE\scripts\install.vbs"
   hs.run "modules\MANAGE.SHUTTERS\scripts\install.vbs"
   hs.run "modules\GET.MARKETPLACE\scripts\install.vbs"
   hs.run "modules\MANAGE.LIGHTS\scripts\install.vbs"
   hs.run "modules\MANAGE.CHRISTMAS.LIGHTS\scripts\install.vbs"
   hs.run "modules\MANAGE.TV\scripts\install.vbs"
   hs.run "modules\MONITOR.NETWORK\scripts\install.vbs"
   hs.run "modules\BACKUP.PC\scripts\install.vbs"
   hs.run "modules\MANAGE.ELECTRICAL.MACHINES\scripts\install.vbs"
   hs.run "modules\MANAGE.CAMERAS\scripts\install.vbs"
   hs.run "modules\MANAGE.ELECTRICAL.RADIATORS\scripts\install.vbs"
   hs.run "modules\MANAGE.FIREBOX\scripts\install.vbs"
   hs.run "modules\MANAGE.MEDIALINK\scripts\install.vbs"
   hs.run "modules\MONITOR.SOFTWARE\scripts\install.vbs"
   hs.run "modules\CONTROL.MEDIA\scripts\install.vbs"
   hs.run "modules\MONITOR.LOG.FILES\scripts\install.vbs"
'-- MACRO TO ENSURE THE SAVE OF ALL DEVICE CHANGES
   hs.RegisterStatusChangeCB "lib\framework_domotics.vbs","traceDeviceChanges"
End sub
3- On a tous des scripts, mais 80% des fonctionnalités sont les mêmes. En créant des modules, j'espère bien trouver des amateurs pour créer à leur tour des modules à publier ... Ainsi, la communauté avancera peut etre (D'accord, la je rève)
4- Au fil du temps, nos scripts se mélangent pour gérer plusieurs fonctionnalités. Avec ma philosophie, je séparer les besoins, et j'ai plus de souplesse pour évoluer une fonction sans en casser une autre !
5- Enfin, toutes les fonctions avancées sont dans un framework (C'est une série de libraries). Ce framework évolue, et j'assure la compatibilité ascendante. Ce qui veut dire, que j'ajoute de nouvelles fonctions, mais je change jamais la signature des fonctions existantes. Donc vous pouvez sans cesse évoluer ... Actuellement, le framework en est à la version 4.10.0. La version 4.x car c'est la 4ieme fois que je refais tous mes scripts ...
Voilà, n'hésites pas à apporter vos réactions ...
Info du jour
Messagede domotics » 04 Avr 2007, 12:26
Salut Ă  tous,
En discutant à droite à gauche, je me suis apercu que mes fichiers dev*.ini et evt*.ini posaient des problèmes de compréhension car ce n'est pas facile de comprendre à quoi sert chaque variable...
En fait, c'est très simple, les dev*.ini sont basés sur la class device de homeseer. Donc vous avez les différentes valeurs possibles dans l'aide de homeseer : /webhelp/scripting/scripting_list_devices.htm
En fait, c'est très simple, les evts*.ini sont basés sur la class events de homeseer. Donc vous avez les différentes valeurs possibles dans l'aide de homeseer : /webhelp/scripting/events/scripting_events_eventclass.htm
J'espère que je vous aurais aidé un peu !
Messagede cedriclocqueneux » 04 Juin 2008, 13:26
Salut !
Je continue un peu mes scripts (y'en a toujours à faire, décidément :D ), mais je pêche un peu sur les conditions dans les fichiers ini des events.
J'ai bien vu qu'il faut mettre
EVT_ABS_TIME=4
puis compléter
EVT_CONDITIONS=
mais là je ne sais pas comment le compléter.
Si par exemple je veux que l'event se lance:
SI il est 7h et que A1 est OFF OU SI il est 10h et A1 est ON.
Un idée de comment tu traduirais ca ?
cedriclocqueneux
Messagede Laser. » 04 Juin 2008, 18:07
Dans l'aide d'homeseer dans scripting/event functions/ NewCondition ou GetEvent il y a quelques explications mais j'avoue que ce n'est pas très clair.
Laser.
Messagede cedriclocqueneux » 04 Juin 2008, 18:38
Oui, j'avais bien regardé l'aide (où j'ai trouvé les paramètres précédents à renseigner), mais pour le reste, c'est loin d'être clair...
cedriclocqueneux
Hello
Messagede domotics » 04 Juin 2008, 19:23
EVT_CONDITIONS n'est pas implémenté dans le framework ... le workaround est de tester la condition dans votre script ...
Messagede cedriclocqueneux » 04 Juin 2008, 19:52
Zut :cry:
C'est dommage, car ca alourdi un peu le système. J'aurai pu faire une condition globale, alors que là, au mieux, il faut que je fasse un script qui se lance à 7h, puis 10h, et qui vérifie si A1 est ON ou OFF.
Tant pis, je vais me débrouiller avec ca :wink:
cedriclocqueneux
framework_x10.vbs
Messagede domotics » 04 Juin 2008, 20:30
en fait, regarde dans framework_x10.vbs, il ya du code entre commentaires. Je me souviens plus, mais surement que je n'avais pas de cas de tests ...
tu peux essayer de le debugger si le coeur t'en dit ....
Retourner vers Homeseer
