Stockage variables
Re: Stockage variables
Messagede davidinfo » 09 Mar 2015, 11:31
Voila un script qui marche chez moi !
Y a plus qu'a affecter les valeurs Ă  tes composants :-)
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports Microsoft.VisualBasic
Imports Homidom
Namespace Dynam
'Ne pas supprimer cette class
Public Class DynamicCode
Serveur=prmParameters(0)
Serveur.log(1, 2, "Macro TEST TXT", "Heure: " & Serveur.GetTime)
Dim FileText as string =My.Computer.FileSystem.ReadAllText("D:\test.txt")
'ex: OPTARIF=HC..BASE=15032045HCHC=7897358HCHP=8753759PTEC=HP..PAPP=0IINST=0
Serveur.log(1, 2, "Macro TEST TXT", "Ligne: " & FileText)
If FileText.Contains("IINST") Then
Dim positionoptionBASE as integer =instr(FileText,"BASE")
Dim positionoptionHCHC as integer =instr(FileText,"HCHC")
Dim positionoptionHCHP as integer =instr(FileText,"HCHP")
Dim positionoptionPTEC as integer =instr(FileText,"PTEC")
Dim positionoptionPAPP as integer =instr(FileText,"PAPP")
Dim positionoptionIINST as integer =instr(FileText,"PAPP")
Dim valueOPTARIF as string =FileText.substring(8,2)
Dim valueBASE as string =FileText.substring(positionoptionBASE+4,positionoptionHCHC-positionoptionBASE-5)
Dim valueHCHC as string =FileText.substring(positionoptionHCHC+4,positionoptionHCHP-positionoptionHCHC-5)
Dim valueHCHP as string =FileText.substring(positionoptionHCHP+4,positionoptionPTEC-positionoptionHCHP-5)
Dim valuePTEC as string =FileText.substring(positionoptionPTEC+4,2)
Dim valuePAPP as string =FileText.substring(positionoptionPAPP+4,1)
Dim valueIINST as string =FileText.substring(positionoptionIINST+4,1)
Serveur.log(1, 2, "Macro TEST TXT", "OPTARIF: " & valueOPTARIF)
Serveur.log(1, 2, "Macro TEST TXT", "BASE: " & valueBASE)
Serveur.log(1, 2, "Macro TEST TXT", "HCHC: " & valueHCHC)
Serveur.log(1, 2, "Macro TEST TXT", "HCHP: " & valueHCHP)
Serveur.log(1, 2, "Macro TEST TXT", "PTEC: " & valuePTEC)
Serveur.log(1, 2, "Macro TEST TXT", "PAPP: " & valuePAPP)
Serveur.log(1, 2, "Macro TEST TXT", "IINST: " & valueIINST)
'Serveur.ChangeValueOfDevice("123456789","dd8764ac-2326-4c97-8504-1425a9011a48",value) 'pour extraire la valeur de la ligne Ă  partir du 7eme caractere (pour enlever "IINST=")
End If
End function
End class
End Namespace
davidinfo
Messagede PAT5659 » 09 Mar 2015, 13:38
Merci beaucoup David
chapeau bas!!!!!quand on a affaire a des pros le résultat est la!!
j'ai fait quelques modifs:
car les valeurs IINST et PAPP ne changeaient pas !
Dim positionoptionIINST as integer =instr(FileText,"PAPP") IINST pour remplacer "PAPP"
et positions:
Dim valuePAPP as string =FileText.substring(positionoptionPAPP+4,1) remplacé par :+4,4
Dim valueIINST as string =FileText.substring(positionoptionIINST+4,1) remplacé par+ 5,2
Après essais les valeurs sont correctes!
Merci infiniment!!
Pat
15 commandes Ă©clairage
Impérihome,Rflink
PAT5659
