| Voir le sujet précédent :: Voir le sujet suivant |
| Auteur |
Message |
acidoracle Membre Actif
Inscrit le: 06 Fév 2006 Messages: 29 Localisation: Montpellier, FR
Posté le: 31 Oct 2007 21:28 Sujet du message: Téléinfo - Linux & PHP |
j'ai cherché sur le web comment accéder sous Linux aux informations du compteur électrique (téléinfo) mais je n'a rien trouvé alors j'ai décidé de programmer une bibliothèque PHP qui réalise cette tâche.
teleinfo.php (nouvelle version)
| Code: | <?php
* PHP-Teleinfo
* v.0.2
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* (c) 2008 Radim BADSI <info AT devbay DOT fr>
/* Definition des messages */
function mesdef() {
$trame_def = array();
$trame_def["OPTARIF"] = array(
"size"=>4,
"desc"=>"type d'abonnement",
"unit"=>""
$trame_def["ADCO"] = array(
"size"=>12,
"desc"=>"numéro série compteur",
"unit"=>""
$trame_def["ISOUSC"] = array(
"size"=>2,
"desc"=>"intensité souscrite",
"unit"=>"A"
$trame_def["BASE"] = array(
"size"=>9,
"desc"=>"index (base)",
"unit"=>"Wh"
$trame_def["HCHC"] = array(
"size"=>9,
"desc"=>"index (heures creuses)",
"unit"=>"Wh"
$trame_def["HCHP"] = array(
"size"=>9,
"desc"=>"index (heures pleines)",
"unit"=>"Wh"
$trame_def["EJP HN"] = array(
"size"=>9,
"desc"=>"index (normal EJP)",
"unit"=>"Wh"
$trame_def["EJP HPM"] = array(
"size"=>9,
"desc"=>"index (pointe mobile EJP)",
"unit"=>"Wh"
$trame_def["BBR HC JB"] = array(
"size"=>9,
"desc"=>"index (heures creuses jours bleus Tempo)",
"unit"=>"Wh"
$trame_def["BBR HP JB"] = array(
"size"=>9,
"desc"=>"index (heures pleines jours bleus Tempo)",
"unit"=>"Wh"
$trame_def["BBR HC JW"] = array(
"size"=>9,
"desc"=>"index (heures creuses jours blancs Tempo)",
"unit"=>"Wh"
$trame_def["BBR HP JW"] = array(
"size"=>9,
"desc"=>"index (heures pleines jours blancs Tempo)",
"unit"=>"Wh"
$trame_def["BBR HC JR"] = array(
"size"=>9,
"desc"=>"index (heures creuses jours rouges Tempo)",
"unit"=>"Wh"
$trame_def["BBR HP JR"] = array(
"size"=>9,
"desc"=>"index (heures pleines jours rouges Tempo)",
"unit"=>"Wh"
$trame_def["PEJP"] = array(
"size"=>2,
"desc"=>"préavis période EJP",
"unit"=>""
$trame_def["PTEC"] = array(
"size"=>4,
"desc"=>"période tarifaire en cours",
"unit"=>""
$trame_def["DEMAIN"] = array(
"size"=>1,
"desc"=>"couleur du lendemain (Tempo)",
"unit"=>""
$trame_def["IINST"] = array(
"size"=>3,
"desc"=>"intensité instantanée",
"unit"=>"A"
$trame_def["ADPS"] = array(
"size"=>3,
"desc"=>"avertissement de dépassement de la puissance souscrite",
"unit"=>""
$trame_def["IMAX"] = array(
"size"=>3,
"desc"=>"intensité maximale",
"unit"=>"A"
$trame_def["PAPP"] = array(
"size"=>5,
"desc"=>"puissance apparente",
"unit"=>"W"
$trame_def["HHPHC"] = array(
"size"=>1,
"desc"=>"groupe horaire (Tempo/HC)",
"unit"=>""
$trame_def["MOTDETAT"] = array(
"size"=>6,
"desc"=>"mot d'état",
"unit"=>""
/* Fin definition */
return $trame_def;
/* Verifie le checksum d'un message */
function checksum ($etiquette, $valeur) {
$sum = 32; // Somme des codes ASCII du message+un espace
for ($i=0;$i<strlen($etiquette);$i++) {
$sum = $sum + ord($etiquette[$i]);
for ($i=0;$i<strlen($valeur);$i++) {
$sum = $sum + ord($valeur[$i]);
$sum = ($sum & 63) + 32;
return (chr($sum));
/* Verifie la taille des messages */
function messize($etiquette) {
$trame_def = mesdef();
/* Renvoyer la taille d'une valeur valide */
return $trame_def[$etiquette]["size"];
/* Ecrire la liste des etiquettes valides */
function etiqlist() {
foreach ($trame_def as $etiquette => $definition) {
echo("<strong>$etiquette</strong> " .
$definition["desc"] . "<br/>\n");
/* Recuperer une trame valide */
function teleinfo ($port = "/dev/ttyS1") {
// Resultat : liste etiquette=>valeur
$trame_array = array();
// Ouvrir le port en lecture
$handle = fopen ($port, "r");
$char = "";
$contents = "";
while (fread($handle, 1) != chr(2));
do {
$char = fread($handle, 1);
if ($char != chr(2)) $contents .= $char;
} while ($char != chr(2));
// Fermer le port
fclose ($handle);
// Supprimer les caracteres debut/fin de trame
$trame = substr($contents,1,-1);
// Separer les messages
$trame = explode(chr(10).chr(10), $trame);
// Verifier les checksum et supprimer les trames incorrectes
foreach ($trame as $key=>$message) {
// Separer l'etiquette, la valeur et le checksum
$message = explode (chr(32), $message, 3);
list ($etiquette, $valeur, $checksum) = $message;
// Supprimer le message si incomplet ou incorrect (checksum invalide)
if (count($message)<3 ||
checksum($etiquette, $valeur) != $checksum ||
messize($etiquette) != strlen($valeur)
unset($trame[$key]);
} else {
// Enregistrer le message dans la liste trame_array
$trame_array[$etiquette] = $valeur;
return $trame_array;
index.php (script de démonstration)
| Code: | <?php
include ("teleinfo.php");
<html>
<head>
<title>TELEINFO</title>
</head>
<body>
<p>
<?php
foreach (teleinfo() as $etiquette=>$valeur) {
echo("$etiquette <strong>$valeur</strong><br/>\n");
</p>
</body>
</html>
Comme vous pouvez le remarquer, la fonction teleinfo() renvoie une trame sous forme d'une liste dont chaque élément correspond à un message (étiquette+valeur) :
| Code: | array(11) {
["ADCO"]=>
string(12) "050512342345"
["OPTARIF"]=>
string(4) "HC.."
["ISOUSC"]=>
string(2) "60"
["HCHC"]=>
string(9) "009666222"
["HCHP"]=>
string(9) "011597038"
["PTEC"]=>
string(4) "HP.."
["IINST"]=>
string(3) "002"
["IMAX"]=>
string(3) "047"
["PAPP"]=>
string(5) "00550"
["HHPHC"]=>
string(1) "D"
["MOTDETAT"]=>
string(6) "000000"
Attention ! Le compteur ne renvoie pas systématiquement tous les messages. De plus, lorsque le checksum (somme de contrôle) d'un message est incorrect, le message est ignoré (seuls les messages valides sont renvoyés).
Je paramètre le port série avec la commande suivante (à placer dans /etc/rc.local pour reconfigurer le port série au démarrage de l'ordinateur)
| Code: | | stty -F /dev/ttyS1 1200 sane evenp parenb cs7 -crtscts |
A+
Acidoracle _________________ X10 & 1-wire & Téléinfo-> Ubuntu Server 8.04
| Revenir en haut |
Posté le: 24 Déc 2007 0:54 Sujet du message: |
| mochel a écrit: | salut
merci pour ton scrpt
comment l'utilise tu ? avec quel adatateur tu va lire les valeurs ?
comment en faire ensuite des exports de données ? des graphes ?
merci d'avance
pascal
et bonnes fêtes |
le script peut être placé sur un serveur web (Apache). Il suffit alors d'aller sur la page web correspondante ou de l'exécuter directement (sans serveur web) en donnant son chemin d'accès comme paramètre à php.
teleinfo.php est une bibliothèque, elle contient les fonctions d'accès à la téléinformation. index.php est une petite page web de démonstration : elle affiche une trame complète (qui lui est renvoyée par teleinfo.php).
J'utilise le montage de dauguet qui marche très bien : http://teleinfo.dauguet.net/ (regarde dans "schéma"). Je crois que tout le monde utilise ce même schéma
Pour faire l'export de données, il faut écrire un petit script. Après, il faut voir par rapport à ce que tu voudrais faire, je peux mettre en ligne (si ça t'intéresse) un petit script qui enregistre périodiquement toutes les valeurs dans un fichier .csv lisible par un tableur. Pour les graphes, je te conseille jpgraph ou Open Flash Chart mais il faut programmer tout ça, mon script n'est qu'une bibliothèque...
Expliques moi un peu ce que tu voudrais faire Tu as quoi comme équipement (système d'exploitation etc.) ?
Bonnes fêtes  _________________ X10 & 1-wire & Téléinfo-> Ubuntu Server 8.04 |
| Revenir en haut |
mochel Membre un peu timide !
Posté le: 24 Déc 2007 9:48 Sujet du message: bonjour |
et merci pour ta proposition de script
cela m'interesse beaucoup de pourvoir en faire un graphique et aussi bien sur de pouvoir l'exporter vers excel par exemple
si tu as le temps ..... merci d'avance |
| Revenir en haut |
MisterT Membre un peu timide !
Posté le: 19 Jan 2008 20:06 Sujet du message: |
Je suis nouveau sur ce forum. Je suis à la recherche d'un moyen d'enregistrer ma consommation électrique instantanée (disons, à la minute ca serait bien), afin d'avoir une meilleure vision de mes (mauvaises) habitudes de consommation, et de les améliorer.
J'ai bien un compteur qui permet la téléinfo, et je suis donc intéressé par les solutions qui tournent autour.
| acidoracle a écrit: |
Oui, je l'avais trouvé également.
Je suis peu expérimenté en électronique, aussi je me demande si personne ne "vend" un module tout fait ?
Ou, mieux encore, un module faisant le lien entre le téléinfo, et un "bus" quelconque (X10, 1-wire, IP Wireless,...) ?
Le but étant de récupérer ces infos sur un PC, pas forcemment localisé à coté du compteur électrique !
Ca, c'est une proposition sympa !
Oui, je suis intéressé par un peu de code sous Linux. De préférence quelque chose de super "classique", comme du Perl ou même du Shell. Ceci parce que je n'ai pas trente six ordinateurs de branchés en permanence dans la maison: seul le firewall (IPCop) tourne 24x7, et je souhaite l'utiliser pour récupérer les données. Or, pour des raisons de sécurisation, cet ordinateur est équipé d'une distribution Linux minimale...
Une fois ces données dans un fichier, je saurai les exporter quelque part (par exemple sur Internet) et faire les pages de visualisation associées... Mais il me manque cette phase de récupération... Donc toute aide est la bienvenue !
Un grand merci d'avance, |
| Revenir en haut |
b10489 Dieu de domotique
Inscrit le: 30 Déc 2006 Messages: 325 Localisation: Dunkerque
Posté le: 19 Jan 2008 21:57 Sujet du message: |
j'ai importé les tableaux issus du programme "adauguet"...sur excel
d'abord un points 1' --> trop de données !
puis en points 5' pour voir nos mauvaises habitudes --> bien
maintenant le relevé est en point 1h et ça suffit...cele me permet de surveiller les consos tempo au jour le jour... _________________ centrale domo "varuna 2" de chez HESTIA
gestion alarme,chaufage,délestage,domotique...
gestion portail
gestion des portes de garage avec automate Siemens logo
11 détecteurs périmétriques + 3 IR
1 detecteur CO + 1 fumées
X10: 8 SW10, 5 am12, 2 ad 10, 2 ld11, 1 ms13, 1 douille,1 FD10, 1 TM13(en renfort)
2 télécommandes NICE+ 1 télécommande HESTIA
1-wire avec 10 DS18b20
2 modules téléinfo, un pour le général et un pour le chauffage (2 compteurs d'énergie) |
| Revenir en haut |
Posté le: 19 Jan 2008 23:22 Sujet du message: |
Voici mon script d'acqusition qui utilise ma bibliothèque postée dans le premier message :
log.php
| Code: |
<?php
* PHP-Teleinfo - script d'acqusition
* v.0.1.5
* Utilisation :
* /usr/bin/php /var/www/dom/teleinfo/log.php >> /opt/dom/teleinfo.csv
* Pour creer le fichier CSV :
* /usr/bin/php /var/www/dom/teleinfo/log.php --header > /opt/dom/teleinfo.csv
* (c) 2007 Radim BADSI <info AT devbay DOT fr>
/* Liste des messages a sauvegarder */
$messages = array("HCHP","HCHC","PAPP","PTEC");
/* Nombres d'essais maximum */
$jmax = 10;
/* Chemin d'acces a la bibliotheque PHP-Teleinfo */
$phpteleinfo_path = "/var/www/dom/teleinfo/teleinfo.php";
if ($argv[1] == "--header") {
$csv = chr(34) . "Date" . chr(34) . ",";
/* Generer l'en-tete */
foreach($messages as $etiquette) {
$csv .= chr(34) . $etiquette . chr(34) . ",";
} else {
/* Lire les messages */
include ($phpteleinfo_path);
$j = 0; // Nombre d'essais
do {
$csv = chr(34) . time() . chr(34) . ",";
$valid_etiq = 0; // Nombre d'etiquettes valides recuperees
sleep(2); // Attendre 1s avant chaque tentative
$trame = teleinfo();
foreach ($messages as $etiquette) {
if ($trame[$etiquette]) {
$valid_etiq++;
$csv .= chr(34) . $trame[$etiquette] . chr(34) . ",";
$j++; // Incrementer le nombre d'essais
if ($j >= $jmax) die();
} while ($valid_etiq != count($messages));
/* Remplacer la derniere virgule par un saut a la ligne */
$csv = substr_replace($csv, "\n", -1, 1);
/* Afficher le CSV */
echo($csv);
Les valeurs sont enregistrées dans un fichier CSV (Comma-separated values) lisible par un tableur.
N'oubliez pas de modifier les paramètres au début du script !
La commande /usr/bin/php /var/www/dom/teleinfo/log.php --header > /opt/dom/teleinfo.csv permet de créer le fichier CSV (/opt/dom/teleinfo.csv).
Pour effectuer l'acquisition périodiquement, il faudra rajouter le script dans votre crontab :
- Ouvrir le terminal
- Taper crontab -e
- Rajouter à la fin du fichier :
| Code: | | 0,5,10,15,20,25,30,35,40,45,50,55 * * * * /usr/bin/php /var/www/dom/teleinfo/log.php >> /opt/dom/teleinfo.csv #Teleinfo logger |
Je vous invite à utiliser un générateur d'entrées crontab pour définir la fréquence des acquisitions (dans l'exemple que je vous donne ici, une acquisition sera effectuée toutes les 5 minutes).
Vérifiez que l'utilisateur dispose de droits d'accès suffisants (fichier CSV en écriture et port série (/dev/ttyS0) en lecture).
Testé sous PHP 5.2.3 & Ubuntu Server 7.10 _________________ X10 & 1-wire & Téléinfo-> Ubuntu Server 8.04
| Revenir en haut |
Posté le: 19 Jan 2008 23:38 Sujet du message: |
| MisterT a écrit: | Oui, je l'avais trouvé également.
Le but étant de récupérer ces infos sur un PC, pas forcemment localisé à coté du compteur électrique ! |
Je crois qu'une personne sur ce forum fabrique des circuits imprimées ce qui facilite déjà énormément la mise en oeuvre de cette interface. Regarde dans la rubrique "Bons plans". Par contre, je crois qu'il n'existe aucune interface compteur-PC "grand-public" puisque la certification est chère.
Si ton compteur se trouve loin de ton ordi, tu peux utiliser par ex. une Fonera (qui est au fait un ordinateur embarqué) placée à côté du compteur et reliée par WiFi au réseau local de la maison. Si ça t'intéresse, je peux te donner plus de détails, je me suis servi d'une Fonera dans un de mes projets d'école d'ingénieur.
| MisterT a écrit: | Oui, je suis intéressé par un peu de code sous Linux. De préférence quelque chose de super "classique", comme du Perl ou même du Shell. Ceci parce que je n'ai pas trente six ordinateurs de branchés en permanence dans la maison: seul le firewall (IPCop) tourne 24x7, et je souhaite l'utiliser pour récupérer les données. Or, pour des raisons de sécurisation, cet ordinateur est équipé d'une distribution Linux minimale...
Une fois ces données dans un fichier, je saurai les exporter quelque part (par exemple sur Internet) et faire les pages de visualisation associées... Mais il me manque cette phase de récupération... Donc toute aide est la bienvenue ! |
Pour diverses raisons, j'ai développé ce projet en PHP (qui peut tourner en stand-alone, sans serveur web, un peu comme Perl) mais ça ne doit pas être trop difficile d'écrire la même chose en Perl. _________________ X10 & 1-wire & Téléinfo-> Ubuntu Server 8.04 |
| Revenir en haut |
Posté le: 20 Jan 2008 0:35 Sujet du message: |
Bon... je vais tenter la fabrication du circuit en premier.
Ensuite la liaison avec le PC.
Enfin, j'essayerai de faire tourner le tout...
Du boulot en perspective, mais merci pour cette aide ! |
| Revenir en haut |
starIST Membre Actif
Posté le: 25 Mar 2008 12:04 Sujet du message: |
Salut
C'est exactement ce que je cherchais mais j'avais juste une question je souhaiterais faire tourner cela sur mon NAS Synology DS207 mais je n'ai pas de port série, si je prends un adaptateur, est ce que cela va fonctionner de la même façon ?
Merci d'avance |
| Revenir en haut |
Posté le: 30 Mar 2008 10:09 Sujet du message: |
Heuuuu un p'tit up  |
| Revenir en haut |
Posté le: 01 Avr 2008 14:09 Sujet du message: |
| Bah personne pour m'aider ? |
| Revenir en haut |
DaRkYoda Dieu de domotique
Inscrit le: 22 Déc 2006 Messages: 782 Localisation: Clermont-Fd
Posté le: 01 Avr 2008 14:29 Sujet du message: |
| starIST a écrit: | | Bah personne pour m'aider ? |
Ben ici t'es sur un forum domotique
Pas sur un forum qui parle de NAS Synology DS207 ...
Donc va plutot sur des forums liés à ce NAS pour avoir ce type de réponse ... |
| Revenir en haut |
Index du Forum
-> Programmation > Logiciels Libres > HEYU, MisterHouse, etc |
Toutes les heures sont au format GMT + 1 Heure Aller à la page 1, 2, 3, 4, 5, 6, 7, 8, 9 Suivante
| Page 1 sur 9 |
Vous ne pouvez pas poster de nouveaux sujets dans ce forum Vous ne pouvez pas répondre aux sujets dans ce forum Vous ne pouvez pas éditer vos messages dans ce forum Vous ne pouvez pas supprimer vos messages dans ce forum Vous ne pouvez pas voter dans les sondages de ce forum
