j'ai pas vu en fait il y a une erreur apres :
50 06/12/18 10:45:45.193 luup_log:608: ALTUI: debug: Data Provider watch provider:emoncms v:[ { "Data": "[ \"3\", \"2\", \"prise_serveur\", \"dff2bxxxxxxxxxx94f\", \"http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}\" ]" } ] <0x77260520>
50 06/12/18 10:45:45.193 luup_log:608: ALTUI: debug: sendValueToStorage: No url, will use callback instead <0x77260520>
50 06/12/18 10:45:45.195 luup_log:608: ALTUI: debug: sendValueToStorage_emoncms(0-69,urn:micasaverde-com:serviceId:EnergyMetering1,Watts,22.9,23.0,1528793145,[ { "default": 1, "type": "number", "key": "nodeid", "label": "Node ID" }, { "type": "number", "key": "feedid", "label": "Feed ID" }, { "type": "text", "key": "inputkey", "label": "Input Key name" }, { "type": "text", "key": "readwritekey", "label": "Read/Write API Key" }, { "type": "url", "key": "graphicurl", "label": "Graphic Url", "ifheight": 460, "default": "http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}" } ]) <0x77260520>
50 06/12/18 10:45:45.195 luup_log:608: ALTUI: debug: watch_description:{ "Data": "[ \"3\", \"2\", \"prise_serveur\", \"dffxxxxxxxxxxxc21494f\", \"http://192.168.1.10/emoncms/vis/realtime?feedid={1}&embed=1&apikey={3}\" ]" } <0x77260520>
01 06/12/18 10:45:45.196 GetLuaInterface can't find device type: 4/0x121bdb8 str: 0-69 <0x77260520>
01 06/12/18 10:45:45.196 luup_variable_get interface 0x172afa8 args 3 <0x77260520>
01 06/12/18 10:45:45.197 LuaInterface::CallFunction_Variable func: variableWatchCallback Device_Variable 69 urn:micasaverde-com:serviceId:EnergyMetering1:Watts failed [string "-- // This program is free software: you ca..."]:3223: bad argument #2 to 'format' (string expected, got nil) <0x77260520>
2
