RFXCOM and water meter
This is a new section created to share our home automation discussions with people from other countries.
Messagede dos » 19 Avr 2007, 21:06
Hi bert,
I have a water meter RF 433MHz PROTOCOL V3 (protocol = RADIAN TM) with a RFXCOM 433MHz/310MHz.I receive data in master raw mode.
Is there an chance that Rfxcom will support this product?
http://www.actaris.com/html/medias/water/SystemeRf.pdf
Domotique : portable 1.0Ghz, 256 RAM, HD 20 Go - XP - apache+mysql+Whomecontrole+erspX10+xap1wire+xapRF +programme perso en php cli.
electricité : current cost cc128
1Wire: 1x DS9097U, 3xDS18B20, 2xDS2405,1xds1990
X10 : CM11 COM/USB, AM12,LM12,LW12, TM13, AD11,telecommande 8 en 1 X10.
RF : RFXCOM 433-310 , 2x géonaute WS 70, 3xMS13, 2xSS13A,5xds10
Ecran tactile: MM500
ServeurTv: Tvengine de mediaportal 2.0/ PIV 2,8Ghz / 512Mo / 260Go Disk
dos
Messagede b_weijenberg » 20 Avr 2007, 04:58
It will be difficult if the data is not received in Variable Length Mode.
If you receive data in RAW mode this indicates that it is a 433.92MHz transmitter and the data is AM modulated. The problem is now how the bit patterns are organized and I have no information about it.
BTW nice product!
b_weijenberg
Messagede human enemy » 20 Avr 2007, 15:57
Hi dos,
I am really interested about your results. I have the same water meter at home and I was wandering if I could get the data with the RFXCOM ??
Can you please tell me more about the "RAW mode" ?
Do you receive a frame ?
Thank's in advance.
<linux user>463160</linux user>
str = g_strdup_printf ("ubuntu user : %d",20328);
PC: Acer AspireOne 2Go HD 250Go sous Ubuntu
Connexion internet: Freebox V6
Mesure électrique: téléinfo en USB vers PC
SOFT Domotique: Atrium (soft perso en python)
Décodage METAR ttes les 30 min pour la météo
ttes info dans une base Sqlite
human enemy
Messagede b_weijenberg » 20 Avr 2007, 16:31
RAW is only for diagnostics purposes and can't be used for data transfer to a PC. RAW mode makes the pulse timing visible. For more information check the RFXCOM receiver documentation.
Bert
b_weijenberg
Messagede human enemy » 20 Avr 2007, 18:02
:cry: :cry: :cry: :cry:
So, I don't see any solution 4 my water meter.
BTW nice product!
RFXCOM is also a great product ...
It's only pity that we users cannot "open" it to non released devices by your company.
Anyway, thank you for your quick answer and br.
HE
human enemy
Messagede InvitĂ© » 20 Avr 2007, 19:13
b_weijenberg a Ă©crit:It will be difficult if the data is not received in Variable Length Mode.
May I use this mode?
b_weijenberg a Ă©crit:If you receive data in RAW mode this indicates that it is a 433.92MHz transmitter and the data is AM modulated.
:D
b_weijenberg a Ă©crit:The problem is now how the bit patterns are organized and I have no information about it.
I am going to try to obtain more information
Invité
Messagede dos » 20 Avr 2007, 19:22
:D
dos
Re: RFXCOM and water meter
Messagede mapo » 20 DĂ©c 2018, 10:36
Hello,
I m reopening this subject, because I have found a link where this Radian protocol is described : http://www.lamaisonsimon.fr/wiki/doku.p ... teur_d_eau
Sorry it french/ english mixed...
I m using a RFXTRX433E with Domoticz on RPI.
Do you think this protocol could be added to RFXCOM ?
Thanks
mapo
Retourner vers Welcome
