Is rfxcom transmitter able to control PowerMid
This is a new section created to share our home automation discussions with people from other countries.
Messagede Sp4rKy » 10 Mar 2008, 09:38
Hi,
PowerMid product has both IR receivers and transmitters. They communicate each with other through 433MHz radiofréquency.
So, do you think it may be possible to record signals and transmit them to the PowerMid IR transmitter ?
Sp4rKy
Modérateur
Messagede b_weijenberg » 10 Mar 2008, 14:56
The RFXCOM transmitter can not transmit data for the PowerMid.
b_weijenberg
Messagede DaRkYoda » 10 Mar 2008, 15:11
b_weijenberg a écrit:The RFXCOM transmitter can not transmit data for the PowerMid.
Are you trying to do it or it's impossible to do ?
DaRkYoda
Messagede b_weijenberg » 10 Mar 2008, 15:24
It is not possible because the IR signals are modulated signals and the transmitter can only xmit On-Off-Keying signals.
b_weijenberg
Messagede DaRkYoda » 10 Mar 2008, 15:57
b_weijenberg a écrit:It is not possible because the IR signals are modulated signals and the transmitter can only xmit On-Off-Keying signals.
But the transmission between Powermid XL transmitter and receiver is 433Mhz AM, does this signal only reproduce IR signal or it's a protocole to trasmit between Powermid and it's not modulated ?
DaRkYoda
Re:
Messagede oliv06 » 03 Avr 2013, 17:04
I have seen that it is the pronto protocol, and there is an open source project ( NetHomeServer PowerMid Connection ) implementing it using the CUL hardware
Perheaps it would be possible to implement it on the RFXTRX ?
Olivier
http://play.with.free.fr
Serveur Domotique: FHEM sur Dockstar avec RFXtrx433 : Oregon, Chacon, OWL, casto - Consommation électrique : Téléinfo USB sur FHEM et emoncms - Misc : squeezebox, Freebox, XBMC ...
oliv06
Re: Is rfxcom transmitter able to control PowerMid
Messagede BlueLotus123 » 16 Déc 2013, 12:02
I don't think there are recording options with the PowerMid product. In my previous office we were using the PowerMid product for communication, and I didn't remember we did make use of the recorder ever. I would suggest try with the technical support team too.
____________________________________________
Ellery
Invalid XML error message troubleshooting
BlueLotus123
Retourner vers Welcome
