Test de 2 caméras IP FOSCAM : FI8904W et FI8918W - Spécifications et Déballage
Note des utilisateurs: / 319
Configuration
API et Application Clientes
Faites une station de surveillance avec votre NAS Synology
Depuis l'iPAD ou l'iPhone
Conclusion et Autres liens pour poursuivre
Spécifications
FI8918W
Image  Sensor Image Sensor 1/5" High Definition Color CMOS Sensor
Display Resolution 640 x 480 Pixels(300k Pixels)
Lens Standard:2.8mm, F:2.4 (IR Lens)
Mini. Illumination 0.5Lux
Lens Lens Type Glass Lens
Visual Angle 67°
Video Image Compression MJPEG
Image Frame Rate 15fps(VGA),30fps(QVGA)
Resolution 640 x 480(VGA), 320 x 240(QVGA)
Flip Mirror Images Vertical / Horizontal
Light Frequency 50Hz, 60Hz or Outdoor
Video Parameters Brightness, Contrast
Night Visibility 11 IR LEDs, Night visibility up to 8 meters
Audio Audio Compression ADPCM
Input Built-in Microphone
Output Built-in Speaker
PC Requirements CPU 2.0GHZ or above (suggested 3.0GHZ)
Memory Size 256MB or above (suggested 1.0GHZ)
Display Card 64M or above
Supported OS Microsoft Windows 2000/XP,Vista,Windows7,Mac OS,Linux
Browser IE6/IE7/IE8,Firefox,Safari,Goolge
Chrome,other standard browsers
Smart phone Support Support phone iphone,Blackberry,Android,Symbian,Windows
Mobile,smart phone support JAVA,
Power Power Supply DC 5V/2.0A (EU,US,AU,UK plug)
Power Consumption 7 Watts (Max.)
Network Ethernet One 10/100Mbps RJ-45
Supported Protocol HTTP,FTP,TCP/IP,UDP,SMTP,DHCP,PPPoE,DDNS,UPnP,GPRS
Wireless Wireless Standard IEEE 802.11b/g
Data Rate 802.11b:11Mbps(Max.)  802.11g:54Mbps(Max.)
Wireless Security WEP & WPA & WPA2 Encryption
Physical Dimension 110(L) x100(W) x108mm(H)
Gross Weight 768g (Color Box Size:200X120X175mm)
Net Weight 418g (accessories included)
Environment Operate Temper. 0° ~ 55°C  (14°F ~ 122°F)
Operating  Humidity 20% ~ 85% non-condensing
Storage Temper. -10°C ~ 60° (14°F ~ 140°F)
Storage Humidity 0% ~ 90% non-condensing
Certification CE,FCC
Warranty Limited 1-year warranty
FI8904W
Image  Sensor Image Sensor 1/4" High Definition Color CMOS Sensor
Lens f:3.6mm,6mm optional, F:2.4(IR Lens)
Visual Angle 67°(3.6mm lens), 42°(6mm lens)
Night Visibility 24 IR LEDs, Night visibility up to 20 meters
Browser IE6/IE7/IE8,Firefox,Safari,Goolge Chrome,
Smart phone Support Support phone iphone,Blackberry,Android,Symbian,Windows Mobile,
Power Consumption 4 Watts (Max.)
Physical Dimension 140(L) x75(W) x80mm(H)
Gross Weight 1.18kg (Color Box Size:243X113X183mm)
Net Weight 766g
Je ne retrouve pas les photos que j'avais pris pour mon déballage. Alors je vous présente une vidéo trouvée sur youtube. Lorsqu'on commande la caméra en Chine, on reçoit exactement ce type d'emballage. Passez par ebay, prenez un vendeur TOP RESELLER. Vous recevrez le colis dans les 8 jours. Si vous optez pour la sécurité, vous pouvez commander ce produit chez Planete-domotique.
Le déballage de la caméra FI8904W est le même que sur cette vidéo de la FI8918W. Il faut simplement noter que le support de fixation de la FI8904 est un peu léger, il n'offre pas une fixation très solide. Il faudra donc prévoir autre chose pour du long terme.
Il n'y a rien à dire sur la FI8918W. Personnellement, je pose les caméras sur des meubles avec une bande de scotch double face pour éviter qu'elles tombent par erreur.
Fixation des caméras
Voici quelques photos qui illustrent comment j'ai installé mes caméras:
Il faut noter que j'ai fixé ma FI8904W à l'envers afin de la positionner bien à l'abri sous le toit. De ce fait, je ne peux pas utiliser la glissière en alu qui est livrée avec pour bien protéger l'objectif du soleil et de la pluie.
Mise à jour le Dimanche, 06 Novembre 2011 21:10
Articles
