[Plugin] Vera pour le RFXtrx de RFXCOM
Messagede lolodomo » 28 Mar 2012, 12:39
Pour télécharger les fichiers du plugin, utiliser le lien Zip archive au bas de cette page.
Installation & Configuration
Produits compatibles et limitations
Voici les nouveautés de la version beta 3:
- Full compatibility with UI7
- Support added for RFY protocol (Somfy RTS)
- Suuport added for Bye Bye Standby new switch power
- Support added for Conrad RSL2 switch power
- Support added for GAO/Everflourish EMW100 switch power
- Support added for Imagintronix Soil sensor
- Support added for swimming pool thermometer WT0122
- Battery level added for Oregon Scientific BWR101/BWR102/GR101
- Fix: usage of devices of type urn:rfxcom-com:device:LWRFRemote:1 and urn:rfxcom-com:device:X10ChaconRemote:1 in the scene editor (UI5)
- Fix: open/close commands reversed for AC window covering
- Fix: light level reversed for Chacon (AC) Dusk/Dawn sensors
- Fix a typo (variable name) in function decodeSecurityMeiantech
- Fix: IE11 compatibility
- UI: different theme for UI5 and UI7, automatically selected
- UI: compatibility with UI6 probably improved
- UI: Ability added to convert a X10 device into a light sensor device ("Managed devices" tab)
- UI: more information about the devices listed in the "Managed devices" tab, including the battery level
- UI: filter feature added in the "Managed devices" tab (by category, type or room)
- UI: deletion feature added in the "Managed devices" tab
- UI: "Learn" command available for GAO/Everflourish EMW100 in the "Managed devices" tab
- UI: "Program" command available for Ikea Koppla, Harrison curtain and RFY in the "Managed devices" tab
- UI: "Confirm pair" command available for blinds/projector screen in the "Managed devices" tab
- Actions SwitchPower and SetDimLevel: default value for parameters in case the action is called without the expected parameters
- Variable KopplaProgrammed no more used
Voici les nouveautés de la version beta 2:
- First UI tab renamed "RFXtrx settings" mainly used to adjust received protocols by the RFXtrx
- New UI tab named "Plugin settings" used to adjust general plugin settings
- New UI tab named "New device" used to create devices managed by the plugin
- New UI tab named "Managed devices" to list all devices managed by the plugin
- New UI tab named "Help" with few help links
- New UI to change the device type (in tab "Managed devices")
- Keep name when converting device to a different type
- Most of logs disabled (can be enabled by setting the new variable DebugLogs to value 1)
- Fixed: management of Meiantech door and motion sensors
- Value of state variables updated only when value changed
- Support added for OWL 180i (cocobalez 's contrib)
- Support added for OWL 113, Electrisave and cent-a-meter
- Support added for Oregon Scientific EW109 temperature and humidity sensor
- Support added for Alecto WS1200 temperature and rain sensor
- Support added for Alecto SA30 smoke detector
- Support added for Livolo switches
- Support added for Livolo dimmers
- Support added for DC106, YOODA, Rohrmotor24 RMF
- Support added for Forest
- Support added for Energenie ENER010
- Support added for Energenie 5 gang
- Support added for COCO GDR2-2000R
- Support added for Chacon CH54741 (X10 motion sensor using X10 lighting protocol)
- New variable Voltage to define your country voltage (used for OWL 113, OWL 180i, Electrisave and cent-a-meter watt calculation)
- Group Off/on: device state is now updated for the members of the group
- Smoke sensors state automatically reset 30 seconds after the last received PANIC message
- 38 actions replaced by 1 unique action for device creation
- 20 actions replaced by 1 unique action for receiving setup of protocols
- Receiving setup of 2 new protocols added (Byron SX and RSL)
Voici les nouveautés de la version beta 1:
- Support added for ARC/AC/LightwaveRF/Blyss motion sensor and door sensor devices
- Smode detector device now created for KD101 in addition to the original device
- Support added for AC window cover device (fensoft's contrib)
- Support added for RFXMeter device (brwblge's contrib)
- New variable DisabledDevices added to disable the automatic creation of certain devices
- Variable RepeatEvent now available for smoke, motion and door sensor devices too: when the variable is set to 0, tripped event is notified only when the sensor state changes
- Fix for Blyss device: group from A to P allowed at creation
- Fix for Media Mount projector screen: remote id parameter taken into account
- Variable NbrDevices added that counts at lua startuo the number of child devices managed by the plugin
- New icon for the plugin device
Voici les numéros de scène à utiliser dans les déclencheurs de scène Vera:
-- ON (activated) / OFF (deactivated): 1-16
-- SET LEVEL: 17-32
-- LOCK (activated) / UNLOCK (deactivated): 33-48
-- OPEN: 49-64
-- CLOSE: 65-80
-- STOP: 81-96
-- GROUP ON (activated) / GRUP OFF (deactivated): 100
-- GROUP SET LEVEL: 101
-- DIM: 102
-- BRIGHT: 103
-- ALL LOCK: 105
-- MOOD1: 111
-- MOOD2: 112
-- MOOD3: 113
-- MOOD4: 114
-- MOOD5: 115
-- PANIC (activated) / END PANIC (deactivated): 120
-- ARM AWAY: 121
-- ARM HOME: 122
-- DISARM: 123
-- PAIR (KD101): 124
-- CHIME (ARC protocol only): 131-146
Quand une plage de valeurs est mentionnée, cela signifie que le numéro de scène dépend du "unit code" du module (de 1 à 16).
lolodomo
Re: Plugin Vera pour le RFXtrx de RFXCOM
Messagede ninux » 28 Mar 2012, 15:28
Merci lolodomo.
Je vais essayer de reprendre ton code pour l'adapter au Plugin RFXLAN le but étant d'avoir un tronc le plus commun.
-VeraLite 1.7
-Jeedom
-RFXCOM Lan XPL
-IPX800v2
-Nas Ubuntu
-5 RPI
ninux
Messagede cyberfilou » 28 Mar 2012, 17:01
Une simple question, est-ce que grâce a ce plug-in, on sait piloter de Chacon ( détecteur + Interrupteur,etc... ), sa m’intéresserais bien
car a la place d'acheter homeseer ( + ses add-on ) et mettre tout sur un ptit PC, je prendrais une VERALITE (moins chers ) + L'antenne RFXCOM
Cyberfilou
2 Détection Chacon ( Couloir ) + ON/OFF Lampe
Etc...etc...
RFXTrx USB + Sonde Oregon
cyberfilou
Messagede lolodomo » 28 Mar 2012, 17:40
cyberfilou a écrit:Bonjour,
Le CHACON est en principe pris en charge par le RFXCOM. Voir sur le site www.rfxcom.com. Par contre, j'ai un gros doute concernant les détecteuirs. Ca doit fonctionner au moins pour les prises et les interrupteurs.
Concernant mon plugin, le CHACON rentre dans une catégorie de messages que je gère déjà mais de manière "expérimentale". Autrement dit, je dois finaliser cette partie du plugin. Ce sera fait je pense d'ici quelques jours.
lolodomo
Messagede sb_domo » 28 Mar 2012, 20:34
Très intéressant ce plug-in. Je me pose également la question d'ajouter un rfxcom à une vera lite pour des prises chacons et surtout des télécommandes x10.
Il y a en particulier une télécommande x10 qui me sert à piloter mon PC et me servait pour des modules x10 que je voudrais pouvoir continuer à utiliser...
Est-ce que ce plug-in permettra d'utiliser du x10 ?
sb_domo
Messagede Mrod » 28 Mar 2012, 20:38
Merci à toi pour ce travail. C'est bien le module RFX en usb ? Si c'est ça, j'investi de suite pour ma véra-lite!!!
Mrod
Messagede lolodomo » 28 Mar 2012, 23:00
sb_domo a écrit:Bonjour,
Oui, pareil, en principe le X10 est géré par le RFXtrx.
X10 lighting, X10 security,
X10 Ninja/Robocam,
http://www.rfxcom.com/transceivers.htm#12103
Et en principe le plugin le gère déjà mais ce n'est pas tout-à-fait finalisé.
lolodomo
Messagede lolodomo » 28 Mar 2012, 23:02
Mrod a écrit:Merci à toi pour ce travail. C'est bien le module RFX en usb ? Si c'est ça, j'investi de suite pour ma véra-lite!!!
Oui, le nouveau modèle qui se nomme RFXtrx433 USB transceiver.
lolodomo
Messagede sb_domo » 29 Mar 2012, 08:18
Vraiment très intéressant.
J'attends un peu que ce plug-in soit finalisé et je pense que je vais me tourner vers l'achat d'un RFXcom USB + Vera Lite plutôt que vers la Zibase 2.
Bravo pour ce travail...
sb_domo
Messagede ZoumZoum » 29 Mar 2012, 13:57
Je confirme bien que les prises "interrupteurs" CHACON / D-IO sont prises en charge par le RFXCom USB. J'ai le moyen de piloter toutes mes prises D-IO directement par l'application proposées sur le site d'RFXCom (RFXCom Manager). Il faut que je regarde comment paramétrer une prise "Dimmable" également D-IO mais vu les paramétrages possibles, ca devrait être jouable je pense.
Je dois avouer que je serais également très très très intéréssé par la prise en charge des module CHACON/D-IO par le plugin, ce serait une avancée incroyable pour nos Vera d'autant que comme dit plus haut, les modules CHACON sont très abordable mais il est vrai que nous n'avons pas le retour d'information concernant son état contrairement à la technologie ZWave... Le fait de pouvoir utiliser les prises D-IO de la même manière que les prise Z-Wave serait un plus pour la box c'est indéniable...
Bravo en attendant pour ce beau boulot, vraiment.
Bonne journée à tous.
ZoumZoum
Messagede lolodomo » 29 Mar 2012, 16:22
ZoumZoum a écrit:Bonjour à tous,
Tu les pilotes via l'onglet Lighting1 ou Lighting2 de l'application ?
De ce que je comprends, Chacon propose des produits qui utilisent deux protocoles différents.
lolodomo
Messagede Lwinter » 29 Mar 2012, 22:10
Bravo pour le plugin : j'ai recu mon RFXtrx hier avec quelques sondes de températures oregon. Tout fonctionne très bien sur une Vera 3 !!
Lwinter
Retourner vers Vera
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 11 invités
